motor bogs down in the lake??
txp35
I have a 1977 rude 75 HP. The motor runs good on the ears but once it is in the lake it has trouble starting and running. It will idle for a while and when I put it in gear it dies. I have changed fuel lines, rebuilt carbs, new spark plug. The last compression test I did was (top to bottom) 110, 100, 90. I have run sea foam though the motor and no major improvement. What do I try next or what could be my problem.
Cricket Too
Re: motor bogs down in the lake??
Did you do a link and synch after rebuilding the carbs?
How is the timing?
txp35
No I didn't, I rebuilt the carbs, ran it in the ears. It ran okay, and then I took it to the lake and it ran bad.
jonesg
In the water, in gear, at idle..
what is the rpm?
around 700-800rpm would be good.
txp35
not sure on the RPMs, I don't have a tach
shamons
I had the very same issue happen with my Johnson 140. Carbs were good, jets were clean, but issue happened exactly as you describe.
I found that I had two problems.
1. The vent hose on my gas tank had gotten some gas in it, and there was a dip in the line, so the gas never left the line. There was enough room for the air to flow into the tank to allow enough gas to move through the system at idle, but when I throttled up, there wasn't enough air space to let gas flow, so the engine would never go wide open. I would suggest checking to make sure your gas tank is venting.
2. The second issue that I had was that I must have gotten some bad gas. I had replaced by fuel filter at the beginning of the season, but I decided to pull it again and found that there was water in the filter. I replaced the filter and put a fuel / water separater on the system so I can drain it. I had to drain it three times last trip within the first 30 minutes, but now it seems to be okay.
I was telling some of the local guys about this, and one of our boat mechanic buddies told me something I had never heard before about the primer bulb. He said that most people install the primer bulb between the gas tank and the fuel / water separator & filter. All of us talking agreed that we all had our boats setup that way. He suggested that we change it up so that we go from the fuel tank, to the fuel / water separator & filter, then to the bulb, then to the motor. He told us that the pressure from the bulb has a tendency to push bad fuel, water, sediment, etc past the filter and has potential to get it to the carb, resulting in fouled jets. I don't know if this is really "best practice", but it makes sense to me and I plan on making that change this weekend. I do have to note that I live in Bethel, Alaska so we do have a tendency to get water in our fuel from condensation on occasion.
Hope this helps. Let us know if you figure out what the problem is.
Spencer
ccnstlr
Lync and Sync sounds like a very likely candidate in your case. I had the same problem and a lync and sync did wonders for me.
