Re: Motor Confusion
Hi,<br /><br />Probably a 25 Hp 4-stroke will make your boat a little to heavy back there and so making it slow to plane but a light 15 hp 4-stroke maybe could be a good compromise?<br /><br />I assume you want manual start (not electric start) and no electric Trim&Tilt since without them you will save weight. But there are 25 and 15 hp 4-stroke with both electric start and electric Trim&Tilt (manual T&T is otherwise standard and electric optional). I do not know if you need Short(S)or Long(L) model (S=431 mm/17.0 inches, L= 552 mm/21.7 inches), that depend on your boat transom height, check your boat(or manual).<br /><br />About weight, compare this.<br /><br />25 hp 4-strokes:<br /><br />Honda BF 25<br />S 148 lbs (67 kg)<br />L 152 lbs (69 kg)<br /><br />Yamaha F25 (AMH)<br />S 137 lbs (62 kg)<br />L 141 lbs (64 kg)<br /><br />---------------------<br /><br />15 hp 4-strokes:<br /><br />Honda BF 15<br />S 93 lbs (42 kg)<br />L 95 lbs (43 kg)<br /><br />Yamaha F15 (AMH)<br />S 99 lbs (45 kg)<br />L 104 lbs(47 kg)<br /><br />Tohatsu 18 hp 4-stroke<br />S 114 lbs (52 kg)<br />L some lbs more<br /><br />---------------------<br /><br />Compare above against 2-stroke, for example:<br /><br />Yamaha 25 hp<br />S 106 lbs (48 kg)<br />L some lbs more<br /><br />Mercury 25 Classic<br />S 114 lbs (52 kg)<br />L some lbs more<br /><br />One of the bad thing with smaller 2-strokes (at least above examples) is they are not so "clean" to the environment. I do not think there are any small 2-stroke that has earned CARB 2006 2-star rating or CARB 2008 3-star rating, that many small 4-strokes actually has earned. For example these 4-strokes has all earned CARB 2006 2-star rating: Mercury 15, Yamaha F15 and Honda BF 15. <br /><br />Check max allowed (hp) outboard for your boat before you decide.<br /><br />You have to check above weights yourself, I do not guarantee they are correct.<br /><br />Good luck!<br />/Bo
