steveo32
Thread starter- Joined
- Mar 15, 2008
- 60
Hi, as most know I am new and I just took my boat out today. The launch went well, the motor started up idled for a while and then I started my line around the lake. I planed out pretty quick and was gaining speed nicely. Hit WOT and started to make my turn. Straightened out from the turn and I could feel a loss of power like the motor was starting to cut out so I let off the throttle a little and engine cut out this occured in about 5-10 minutes worth of driving. Took me 20 minutes to get the boat to the side where a resident asked what happened? You were going great and it just died. I aggitated at the time said yeah I know. So I began to drag the boat by the shore and of course it kept getting stuck in the sand. So about 100 ft from the boat launch I was fed up and just got in the water calf deep (temp outside was 44F so water was f ing cold) and started pulling the boat until I got to the boat launch. Spark plugs are wet fouled, they were brand new too. Tried several times to start with no avail. Carbs were flooded. Tried when I got home on the muffs too with no luck. the motor turns over and sounds like it will start but doesn't. Motor is a 1975 70 hp 3 cyl, it had started every time on the muffs before this. Tell tale hole has water coming out wit the muffs. Couldn't see on the lake because the water above tell tale when I would lean over the back to look, I weigh about 215lbs. So what else do I need to check.
Thanks
Thanks
