mcgreavster
Thread starter- Joined
- Feb 27, 2017
- 58
88' XP 150 will idle perfect all day long, I'll go to throttle down and it gets up on plane really quick with lots of power and everything seems great until about 15-20 seconds later when the motor just dies. It doesn't seem to sputter or matter if I back off the throttle, it seems to just be instantaneous so I'm thinking an electrical issue? It'll start right back up after and it'll be the same as before.
My tach hasn't really worked since I bought the boat late last year (kicks on for a minute or two here and there). So today I moved my gray tach wire from the rectifier to the yellow/gray stator wire and the rpm tach started working again. Also I checked the volts on my battery before running it (12.7V), during running (12.56V), and then again after I shut motor(12.67V).
So I for sure have a bad rectifier but I don't know if that would cause my motor to die after full throttle? I've read it might be more of a Stator or Powerpack problem? By the sounds of it running with a bad rectifier can eventually cause your stator to overheat, and after inspecting my stator from under the flywheel it does appear to have some black possibly melted material on it.
Does anyone have any ideas what my problem might be?
