Motor Gaskets
jimrockireland
Can I buy gaskets (head; valve cover; water pump; exhaust and intake manifold; carb; etc) for a 1983 mercruiser 305/5L MCM228 engine from an auto parts store or do I have to go to a marine supply store? Basically is there any difference between marine gaskets and auto gaskets?
Re: Motor Gaskets
Ayuh,... So long as ya buy Quality composite gaskets, nope it don't matter,...
Re: Motor Gaskets
You can buy from auto parts stores so long as they specify for your marine engine. As an example the intake manifold gasket for a car has water flow through the intake, where a marine engine does not.
Edit: well guess I got it wrong again :facepalm: sure could have figured it since mine does.
Re: Motor Gaskets
Huh,..??..?? So how does the water get to the t-stat housin',..??
Re: Motor Gaskets
My bad again, dang that's two in one thread. It's not water it's exhaust transfer through the center, and now that I think of it my rear water channels are blocked of on my 502. Had to repair the intake the last time I had it off due to a slight water leak
