Liquid_force
- Joined
- May 7, 2003
- 318
Hey - finally found the time to finish de-winterizing and went to the lake for a check.
Started and ran well - as expected. After running for a couple minutes I discovered a pretty steady water leak toward the top of the engine. The thermostat housing wasn't properly torqued which was causing a steady shower from the top of the motor down.
I tried to limp it back to the dock about ~50 yds away. About that time the engine died and wouldn't restart.
Towed it in, tightened the therm hsg bolts and tried repeatedly to start but wouldn't.
It would fire and run for a few seconds when I manually primed the carb - otherwise nothing - acting like it wasn't getting any gas.
I'm assuming a "water in the gas" issue. What would be the steps to remedy this?
My hope is that just giving it plenty of time for any water to evaporate, filling with fresh fuel (currently 1/4 tank), and possibly replacing the water/fuel separator will do the trick.
I suppose it would be a good idea to siphon what fuel is in it, but...ugh.
