Re: Motor Guide 71 foot pedal tension
remove the top cover. then remove the screws (8)from the rack assy. then lift the rack assy. off of the pinion gear. you can lift it up far enough to do this without cutting the wires. you will notice a allen set screw that locks the pinion gear, loosen the set screw, you will now be able the turn the pinion gear. turn the gear clockwise just a little, then tighten the set screw back down. this will load the bearing assy. just a little more. adjust till you get the tension you feel comfortable with. just make sure you get the set locked back down. then reassemble rack guide assy. and top cover. let me know how everything turns out, or if you have any more questions.
