I have a 1971 60hp johnson, 3cyl. Motor has trouble with a slow idle as it wants to die, I took it to a mechanic and it will idle a little better it has a miss. He adjusted the points and says that he can pull off plug wire 1 and 3 and it don't make much difference, but when he pulls off #2 motor boggs. All carbs have been cleaned and set, timing adjusted, and all plug wires are getting fire. any help out there
