Motor has no top end....
suzuki40
Re: Motor has no top end....
Ok, Bear. I bought a new connector that snaps on the gas tank. Found out today that the fitting that connects the fuel line from the tank to the motor is one from a mercury that I had on there before. I thought they were interchangeable. I was told they were not. Got one today at walmart for my Meriner.When it gets a little cooler today Im going out to change it out. I hope this fixes things. Because there is nothing else to change?<br /><br />I'll let you know,<br /><br />Suzuki40 :confused:
suzuki40
My persistance is going to put me in the poorhouse. I am going figgin crazy with this darn thing.If this dont do it....Im throwing it off the back of the boat. and using my trolling motor to get back.<br /><br />Suzuki40
suzuki40
Everything is brand new from the carbs to the gas tank. and a large list of others. I guess im going to have to take it to the Mechanic tommarow... there goes big bucks.<br />Motor is starting and running fine,except when I throttle down on it, run about 10 seconds and looses prime in the bulb??? pump it up and it will run great. I can sit there and pump it as im running full throttle and it will do just great for as long as I keep it primed?<br /><br />Suzuki40 :mad:
mellowyellow
go back and inspect all check valves and the tank<br />pickup again. what type fuel tank r u using?<br />have seen lots of NEW defective primer bulbs.<br />can also try this:<br />take off cover and push throttle wide open.<br />as it starts boggiin down, tap on the side of<br />the fill bowl with but of screwdriver. if this<br />fixes, got a bad float. (are floats new?)<br />are check valves in pump new? in right?<br />from left field:<br />once had my local shop sell me the wrong gaskets<br />for the fuel pump. diff. was so small, could hardly<br />tell they were wrong. caused same exact symptoms.<br />good luck,<br />M.Y.
The Marine Doctor
The carbs....do they have the fuel pumps built onto them?<br /><br />If so...the gasket that you mount them onto the intake with has a small hole in it...and MUST be aligned with the hole on the intake as this is where the pulse is recieved.<br /><br />TMD
suzuki40
Hey mellowyellow,<br />I have looked up the part #'s myself to check if the parts I got were right. They are. I have had friends that work on boats all the time come over and check this out. I have replaced the bulb and fuel lines three times. tore the carbs down three times.(with help) 5 well experianced fellas have come over to figure this out. same story every time. Everything related to the fuel delivery is new ( a couple of times). Motor runs like a champ, couldnt asked for it to do better. as long as you pump the bulb.<br /><br />Suzuki40
suzuki40
Hey Marinedoctor,<br />I have done this every time I have taken the carb off. we are very maticulas (howerver you spell that) at every thing we do now.I just feel like burning it! but when I find out what it is. I'll let you all in an the secret, you all have been very patiant with me and very helpful.<br /><br />Thanks,<br />Suzuki40
suzuki40
Problem Solved!!! WHOOO HOOO!!!<br />I had a frind come over today that had a vacuum pump. he put it on the fuel line at the tank and pumped air into it or he sucked air out I dont know. When he did the "T" that directs the fuel to each carb had a crack in it. it whistled like a tea kettle. I must have cracked it putting the fuel lines on. anyway I replaced it and took it out for a test run. Smoooooth as silk. Thanks for all the inquieries and keeping my attention on the fuel system. Ya'll are great and very helpful, Bear and Mellowyellow...Thanks a bunch.<br /><br />This thread is done,Bye<br /><br />Suzuki40 :D :D :D
suzuki40
Hey, The Marine Doctor, I did forget about you. Thanks for all your help.<br /><br />Suzuki40
mellowyellow
well done dude! :cool: way to keep at it...<br />was expecting next post to say; "the "shop" said<br />I need a new (input expensive part), what do you<br />guys think?" LOL<br />a very good thread that will help lot's of folks.<br />safe boating,<br />M.Y.
suzuki40
It was a mess for sure but I weeded it out. Thanks again Mellowyellow.<br /><br />Suzuki40 :D
mellowyellow
they are thirsty girls for sure! don't deprive them<br />of what they need and they will treat you good.
Bear
Great job! <br />It was fun wasn't it? You know a lot more about your engine by now. <br /><br />Happy boating!<br /><br />(Don't forget to clean your keyboard)<br /> :D :D
suzuki40
Hey bear, Just got in from the lake tonight. I had a great time and trouble free. I bet I went about 15 miles tonight fishing for Black Bass. caught only one tonight but I didnt have to worry if I was going to make it in either. This web sight paid off in spades! I would have givin up if not for you and the other helpful folks here. My congrat's to you all Thank you and may we work another big one out for someone else tomarrow.<br /><br />Suzuki40 :D :D :D
