Re: Motor Height
With your rig I'd guess you could easily run at a moderatly elevated height. If the motor's sitting directly on top of the transom that's way too low. Assuming the shaft length is correct for the hull that is. If it were me I start with the cav plate at least even with the keel, mebbe 3/4" higher, and see what happens.
I ran a full 2" above the keel with a 90 on my 15'3" Glastron. Only problem I ever had was if I was running really hard flat out for more than say 5 minutes. I'd get a high temp alarm. And that only happened in the heat of summer when the water's real warm.
Note: If you start getting up there you might wanna look into a semi-surfacing prop aka chopper. Good luck!
