motor height?
Terry H
Re: motor height?
When you say hopping, are you talking about porpoising?
Dhadley
Re: motor height?
First things first. How did you confirm the tach is correct?<br /><br />Let us know!
rlguns
Re: motor height?
I borrowed a hand held tach and went to river,I tried 2 styainless 3 blade props 1-19 pitch ,1-21 pitch.Yes i mean porposing :confused:
D
DJ
Guest
Re: motor height?
rlguns,<br /><br />Basically what porpoising is telling you is that you are over trimmed "up". One of several things is happening. 1. Your engine doesn't have the power to hold the bow up. 2. Your prop doesn't have sufficient bite to hold the bow up. 3. You are front heavy on the boat which is relative to the last two.
rlguns
Re: motor height?
what i am still thinking is my jackplate is too low.Im gonna raise it 1 inch and try then bring down in increments.Do yall think this may help? :confused:
D
DJ
Guest
Re: motor height?
I would try to get rid of the porp. first. You're too high now.
rlguns
Re: motor height?
I do trim it up quite a bit before it starts porposes.The rpms never get past 4700 .I dont think they will unless i raise it up out of the water.Ive tried a 21 and 19 with no diffrence whatsoever. :confused:
Terry H
Re: motor height?
Riguns...your porpoising problem is most likely caused by trimming up too high. I have a similar boat/motor setup and I run a 17" prop when I am loaded or pulling a skier. A 19" prop will get me to wot with no load. I don't have p/t so porpoising is not a problem, when I first set up the boat I raised motor enough to make it jump real good. I think yo are over propped. See if you can find a 17" to try out...just a Thought
pioneer
Re: motor height?
i thought that once on the plain, the bottom plate should be just at water level
rlguns
Re: motor height?
My problem is not the porposing.It is that i cant get pasr 4700 rpms and 42 mph.Have tried 2 props with exact results.I am thinking my motor needs lowered but not sure. :confused:
