motor length
Boat Drinks
Honda BF25A by tape measures 22". Is this normal for Honda? Transom heights are 15,20 or 25"???
chevyjet
Re: motor length
I would not call it normal but i have seen it before on some yamahas, the best thing you can do is bolt the moter on higher so that the anticavitation plate is in line or about half an inch below the boat bottom.
Hope this helps
Boat Drinks
Re: motor length
Thanks for the info. It's really odd. I need to build up the transom (it's a 15) and every way I measure the motor it comes up with 22. That puts the bottom hole at the top of the bracket awful close to the top of the stern. Looks like I'll have to build it higher and change it if I change motors.
lots of boats
Re: motor length
Hi
The yamaha enduro 60's all needed 22-23" transoms, sometimes we set them to 22" and found they didn't cavitate so we set them one hole higher.
A 7" transom jack usually needs some braces.
