JCurry2885
Thread starter- Joined
- Jul 20, 2017
- 32
Motor is a 78 Evinrude 115. Lower unit was cracked so I sourced another one. Motor cranks and runs fine with the lower unit removed, but once I install my new "used" lower unit the motor is locked and will not spin. I already made sure that the unit is not in gear, as I can spin the prop shaft freely. Also the lower unit driveshaft rotates free when it is not installed onto the motor. I had no issues installing the lower unit onto the motor, I just rotated the engine a little to line the splines up and it slid right into place, I did not have to force anything. Shift shaft length is adjusted correctly. Only thing im finding different is my driveshaft length on the new lower unit is about an 1/8 inch or so longer than my old one, but I didn't figure that was an issues since the unit installed so easy, and I did not have to force anything.
Any ideas??
Thanks!
Any ideas??
Thanks!
