Motor loses Power ?
slamer12
OK im really going nuts with this i changed my fuel pump VRO and changed primer and filter but im still having problems when im in idle the but idles fine and when i give it throtle it is gtreat no problem , Now when i put the boat in gear and start to give it throtle she stallls out @ around 2000 RPM , if i baby the throtle sometimes i can get it past the 2000 rpm point and then i can open her up but it seems at first when i start to give it throtle it keeps choking out any suggestions or ideas please help thanks !!!
JB
Re: Motor loses Power ?
Since we have no idea of the make, HP or year of your engine we can't be much help, Slammer.<br /><br />In general terms, it sounds like it needs a link 'n' synch job and may have a sticking stator.
Dhadley
Which 1995 115? The crossflow or the 60 degree looper?
slamer12
Hey J.B. what do you mean by link n sync job and whats is the stator ???
slamer12
i checked it with a portable gas tank with quick connect and it ran for about five minutes then it started to stall again what do you guys think ?
CATransplant
Time to get a service manual for that engine. You'll have all the info you need to do that link and synch operation, along with other valuable information.<br /><br />Without it, you're working blind. With it, you'd have your engine running right pretty quickly.
