Motor mount question on transom
BOAH
I have a '72 Starcraft (aluminum) and I'm mounting a '98 Yamaha 115 on it. The transom is 1 3/4" wide and the bracket on the Yamaha is 3 1/4". Does that make any difference when I mount it that the bracket is that much bigger or do I need to put in some type of spacer?
Thanks for your help!
boobie
Re: Motor mount question on transom
You should post this in the Yamaha section of this forum.
82rude
no it wont matter .when you bolt it up, the motor will hang tight against the transom.
BOAH
Thank you 82rude
