motor on pram
kayakn
i am going to get an 8' pram and a 2.5 horsepower motor to go on it while i am not sailing or rowing it. i was wondering how fast it will go and if there is anything i should know about motoring it.
thanks, kayakn
tashasdaddy
Re: motor on pram
boating safety, depends on the pram, and load. calm water only.
kayakn
Re: motor on pram
the boat is an Optimist Pram there is probably only going to be 350 pounds max load at the most. but mostly it is going to be around 200 pounds max in a small creek with not many waves.
bjcsc
Re: motor on pram
The speed (in knots) will be the square root of the length of the water line measured from the middle of the transom, around to one side, and to the point on the bow x 1.34. Generally, you want 1hp for every 500lbs total weight to reach hull speed.
Is a pram a gaff-rigged catboat / rowboat of sorts? (never heard of one)...
kayakn
Re: motor on pram
a pram is a gaf-rigged small flat bottom boat. the one i have is an Optimist Pram that can be sailed, rowed, and i am going to try and motor it
bjcsc
Re: motor on pram
Unless you plan on planing it (I wouldn't) that formula I gave you will give you your hull speed and the 2.5 should be more than adequate to get there. The only major consideration I can think of is submersion, i.e. many small sailboats roll quite easily. I've tumbled my Hobie 16 end over end quite a few times...
kayakn
Re: motor on pram
this boat is what they use to train kids to sail and is said to be very safe. i will try the motor and will go very slow and see its limits, and if it does not work i can just sell the motor and sail and row it.
bjcsc
Re: motor on pram
OK, then it's probably pretty beamy. I think it will work fine...
steelespike
Re: motor on pram
If your running without the mast it will probably be fine.2.5 is more than enough to reach hull speed.Just be sure the transom is strong enough for an outboard.
