motor outboard
joven2324
i just want to know if i can put a 175hp force outboard to my bayliner 19 ft capri, originally it has 90 hp ob but when i bought it the motor was completely not working so im still looking for a motor to put on the boat. can somebody help me pls!!! and how long is the shaft to fit my bayliner capri boat? (outboard)
trendsetter240
Re: motor outboard
Hey joven, check the back of the boat for a metal plate that states the maximum horsepower allowed. You should not put a motor on that is more HP than the boat is rated for.
The bayliner is most likely a 20" transom. To find out for sure, take a measuring tape and meaure the transom dead center from the top where the motor sites to the bottom of the hull.
Welcome to iboats!
roscoe
Re: motor outboard
No you can't, for 2 reasons.
The boat is not rated for 175 hp.
And Force never made a 175 hp motor.
joven2324
Re: motor outboard
im sorry i mistakenly type 175force, its johnson 175 hp, my bad.
thanks so much, how about suzuki bran,you think the hole will fit in my boat?thanks again
roscoe
Re: motor outboard
Somewhere back in the late 1980's, all outboard brands started using a standard BIA bolt pattern. You can always drill new holes if you need to.
Most important is to get a decent running motor.
