duckhunter55
Thread starter- Joined
- Oct 13, 2007
- 94
Ok im back again with my 25 hp 1978 JOhnson. Finally got motor started. Took to lake to run it. Started up and checked exhaust to see if it was pumping water. Was pumping water, but not as much as i thought it should. Thought it wouldn't be a prob seeing how i was just going to check and make sure motor ran around the ramp. BIG MISTAKE? Was on way back to ramp after about 5 -10 mins and motor cut off. Opened hood, smoke came out. Motor was very hot. Did not attempt to start. Took back to ramp put on trailer. Flywhell still turns over by hand. Seen that around lower cylinder paint was discolored, brown. My Q is, what are proper steps to trying to get motor running again. Last time i had lower uniy off and looked at water pump all looked good. Impeller was not cracked or broke, pump housing looked fine. What would make it not pump water good. Did notice that copper pipe did not fitt to well into rubber grommet. Also when you put impeller into housing should you crush housing down on top, or put in by hand? And laslty are the 2 holes on back of leg housing the only holes water should come out of? Sorry about long post. Any help greatly appreciated! Also how does water get from end of copper pipe to powerhead and back out exhaust?
