Motor reliability for 9.9 hp
rg2
I currently own a Polarkraft MV1571 which had a Merc 6hp 4-stroke on it when I bought it. I would like to have a little more speed therefore I am looking at the 9.8/9.9 models. (In Illinois we have alot of 10hp limit lakes that I would like to use.) Is there much difference in top end speed in the high thrust and standard models?
Any brand preference between Yamaha, Mercury and Tohatsu. I keep reading that Merc and Tohatsu are the same motors but the local dealer says they aren't. WHAT IS THE TRUTH??
Thank you.
ezmobee
Re: Motor reliability for 9.9 hp
Tough to go wrong right now. No one makes a bad 9.9 that I know of.
Mike Robinson
I don't know whether the high thrust motors would give you more speed but I suspect they just give more "oomph" for trolling with a larger boat. I can say that when I worked in the sportfishing industry about 7 years ago, the Yamaha 9.9 HT's we used provided excellent service.
cwhite6
I own a Nissan/Tohastsu 25hp motor and it is absolutely bullet proof. I know Mercury and Nissan did have the same motor, but I am not sure when and what hp models. Post in the Nissan forum on here for outboards. There are some really knowledgeable folks on there that can set you straight.
jeff_smith_0423
The Tohatsu 9.8 and Merc 9.9 four strokes are the exact same motor with a different shift/throttle control arrangement. They're built in a joint venture factory in Japan. Any Merc dealer who won't tell you this doesn't deserve your business. The Tohatsu/Nissan's can be had for a good bit cheaper if you have a dealer in your area. Good little motors. Several guys on my home waters have them.
