Cady8special
Thread starter- Joined
- Aug 24, 2011
- 64
Hey guys,
Just picked up a 1999 Mercury 135HP V6 Carbed model. I ran it for about 30 minutes the first time out. Bogged a little out of the hole but got up to speed ok. Last night, I ran a decarb- one bottle in 3/4 gallon of gas method- 15 minutes at high idle, 15 minutes off. I kept checking the heads and tell tale- everything was warm- not hot. After the third 15 minute cycle, I hooked up the main gas line again and tried to blow it out. I got to about 2500 RPM's I'd guess, and it started to bog down and wouldn't even plane. I didn't want to push it for fear that the carb was clogged. I checked the heads and they were pretty hot. About 5 seconds is all I could take with my hand on the head. Starboard side felt a bit hotter. Good tell tale stream- new pump. Would you guys suspect a clogged carb? Also, not sure if this is relevant or not, but the top and bottom plugs on the starboard side were flashing while it was running. Does this mean anything? I was thinking about taking it out today- just booting it for about 20 seconds to see if it clears itself out. If it gets hot, I'll get it cool down before puttering back. What do you guys think?
Thanks.
Thanks.
