motor runs out of fuel
meandean
I have an old Johnson 10 hp. I have to keep pumping the primer button on the tank. Could it be a bad gasket in the fuel tank.
meandean
Re: motor runs out of fuel
The tank has lots of pressure when I release the cap.
meandean
Where can I get gaskets for this old two line tank or can I buy a new tank?
tashasdaddy
you can cut your own, we use to use old inner tube. you could have a clogged or dirty pickup tube in the tank. another thing is you float in the carb may be stuck, not allowing gas to enter with out the extra pressure of your pumping. may try a carb rebuild with new float, complete soaking 24 hrs. then blow out all orafices with compressed air. i have a '55 15hp rude such a sweet engine.
