I have a new to me 24 foot Crestliner Pontoon boat that has 26 inch pontoons. The prior owner switched motors on it from a 50hp to a 115. The 115 is a short shaft Yamaha 2 stroke and it is lowered down as far as it will go on the transom. The AV plate on the motor is a couple of inches above the bottom of the pontoons and the motor cavatates pretty easily if you start to trim up or turn. The boat does not have lifting strakes. I have noticed that some of the pontoons I have seen seem to have the AV plate close to the bottom of the pontoons, but that has been looking at them from a distance as I ride by boats on lifts.
The prop is a 13 x 15 3 blade Turing point that I just got to replace one the same size that was damaged prior to my ownership. I wanted to see where the AV plate is on most peoples Pontoons in relation to the bottom of their pontoons. Right now I am looking at either making a jack plate to lower the motor or getting a 13 x 13 four bladed prop to see if it will get a better bite.
When I brought the boat home it had a stainless prop on it that was over pitched, but I do not remember having any cavitation issues with it. Thanks for any help or ideas.
