Boat starts up fine in the water, for the first couple of minutes I can get it up to about 1900rpms before it wants to crap out. At first, i can sometimes get it to "surge" if I give it a lot of throttle, then eventually, not at all. Then, upon starting it again I can only get slightly above idle before it dies. It seems to worsen over a short period of time. It also seems to die suddenly as if it isn't getting enough fuel or spark. I've been using an auxiliary tank to rule out water in the fuel. The ignition was converted with a presto-lite ignition module in the distributor that came out of an older, junked boat.
Here is what I have tried so far:
I first had the carb rebuilt, however, after having it rebuilt I did run it and then found a substantial amount of water in the fuel. I've since used an auxiliary tank and run clean fuel through it for about 30 minutes.
It has a new fuel pump that has been tested at 6.5 pounds pressure.
A mechanic put a new coil on it, I have since been told by another mechanic that it is the wrong one (I have a Sierra Thunderbolt on order).
I've been told that the presto-lite ignitions either work or they don't work at all, I've also been told that they are junk.
Is it also possible that there is still water in the carb?, in the bowel?, can I, how do I drain it if this needs to be done?
Even with what I've done so far the symptoms seem to be the same.
Any help would be greatly appreciated.
Thanks,
James
Thanks,
James
