John Gawlik
- Joined
- May 5, 2003
- 3
I have a merc 260 that stalls when I put it in gear. I just got this boat and I have found that the choke plate on the 4 barrel carb is wired into a certian spot. The motor will start right back up with no problem. After a while i can get it in gear and drive off. I have noticed the volt gauge and techometer drop molmentaraly at the same time even if I do get it in gear. Other then that the boat runs fine. I guess I could try a tune up but not sure this would help. Any inputs would be appreciated. Thanks
