Motor still idles after shut off?
Kalani 938
Hey guys I've got a question for you. I have an 06' Tahoe Q4 with a 4.3L Mercruiser 190hp. I purchased it last October and have only ran it about 5 times. I took it out for the 2nd time this season yesterday and it cranked right up after we unloaded it and it ran across the lake just fine. I then turned the key to shut it off and it kept idling kinda rough for about 10 seconds and then died. Well, when I tried to crank it again it would idle for about 5 seconds and then die. The idle was very low, almost like it wasn't getting enough fuel? After about 20 minutes of this I turned it over and while it was idling low I put it in gear and it took off and ran okay. I then adjusted the idle screw b/c it seemed to be idling lower than normal. Then I ran it for a while and it just seemed like it wasn't running right? Sounded a bit different and just felt different all around? Kind of hard to explain exactly what was different, but all you boat owners know what I mean when your boat just doesn't seem right. When loading it up I killed it and it took a good ten seconds again for it to stop idling and die? Anyone have any idea what this could be? I did put stabil in it over the winter.
Kalani 938
Mercruiser still ideling after shut off?
Bt Doctur
Re: Mercruiser still ideling after shut off?
Timing is off, carb adjusted too lean, engine temps too hot, wrong heat range spark plugs.
Kalani 938
What's strange is that the first 4 times I took this boat out I never had a problem with this? Engine temp seems to be normal. Can anything happen over the winter while it is in storage for these problems to occur?
Ayuh,.... That's why We do Winterizations,+ then Summerizations....
dontask
Try running the engine while warm and do what is called "cylinder drop method" of trouble shooting. What this is---you remove one spark plug wire at a time while the engine is idling warm and the cylinder wire that you remove that does not (NOT) cause a loss of idle speed is a cylinder you need to look at. Obviously put that last removed wire back on before you move to the next cylinder. Check the spark plug condition, the plug wire, any vacuum hose or fitting near by that could be causing a lean mixture to that one cylinder. if you suspect one of those components swap it over to a known good cylinder and see what happens. Spark plugs can look good when removed but have conductive flash deposits you can't detect. If all of the cylinders drop the same amount in rpms then you know its not cylinder specific.
After you pin point your cause return you idle rpm back to factory specs and your "run on" condition should not be an issue. Also check out (Google) why "anti dieseling solenoids" were installed on some engines, and get your throttle plate back were it belongs for idle. The plate helps to starve the engine at cut off--- of air & fuel.
JustJason
How about a full tune up. When was the last time one was done?
deves3000gt
If the boat didnt turn off after turning off the key i would check the ground of the ignition switch. IMO that is your problem. If the switch is bad and was still grounding a bit after you started it that could be your prob. The way you said it ran rough for a few sec b/f turning off it didnt ground right.
JustJason
Uhmmm.... last time I checked... and I check quite a few a month.... IO keyswitches are not grounded.
A lot of outboards have grounded keyswitches though, if that is where your confusion is from.
dontask
Years ago we used to replace lots of parts when we couldn't trouble shoot and pin point the problem. For example whole sets of plug wires were changed, cap, rotor, condenser, plugs, etc etc. Why spend all of that money and time if it is not needed? It could be one small inexpensive part changed and issue resolved. Unless you want to throw money away or it makes you feel good to have new parts, change only what is needed & when it is needed.
JustJason
Doing a tune up is not called throwing parts at something... it's called preventative maintenence. It's also required by Mercruiser... not by me.
deves3000gt
Ok maybe I am taking about things i dont know. If the moter is not turned off though a ground please school me on what turns them off. Is it a fuel shut off like a diesel?
JustJason
The ignition system gets its power through the keyswitch. All your doing is stopping power from getting to the ignition system by turning the key off. Has nothing to do with grounds.
Fun Times
It sounds like you have too problems to start with one is the fuel may be old or it has water in it at the fuel filter you could remove it and check it for water or varnish it will look like a oil filter but it will read water seperater fuel filter and it should be down on the lower left side at the front of the engine as you sit on your knees looking at the engine, It will unscrew like a oil filter just have a few rags and I use a clean coffey can to poor it into And look at and smell it. Have you ever boughten fuel from a fuel dock marinea while on the water? the other thing that will make it stay running after shuting it off is the idle is to hi, That engine should idle smooth at 640RPMS you will nee to aujust the idle when warm to 640rpms, The right way to do this it unhook the cable at both ends [don't loose all the nut hardware:) then rev the enging for a second to clear it out as the engine is coming down to a idle you will want to see on the RPM gauge the idle speed to go down to 640 rpms, But first you should notice as you start to play with it a little [this will take some time to do so hang in there with me on this one] As the engine is coming down you will want to hear and see the enging idle a little higher at first around 750 RPMS then you will want to slowly aujust the idle speed screw down till you hear the engine speed drop down on it's owen to 640 rpsm that drop down is the modual aujusting everything out to get a smoother idle speed, Now you will want to have the idle screw aujusted to the higher side of the idle speed at first then you need to rev the engine up and let it come back down and then you want aujust it so that when at first it will be at 750 rpms and then within 1-3 seconds you will want to here it and see it drop from 750 down to 640 rpms and that is where you will want it to run at so it will run it's best that it can. While doing the "Aujustments" and trying to "Fine Tune" it and find the TIME FRAME [1-3]second of the drop down speed I will some times pull back on the stud a little to see how much more I think I will need to turn the screw down to find 1-3 second Hi idle before it drops down on it owen for a good idle speed and aujust as needed. Now the hard part hooking up the cable might mess up some of that aujustment you just did a little becuase you will need to aujust the cable so it has a little tinshion on the cable to keep it at idle so you will need to turn the black knob back towred the rear of the boat with a varry small amount of pressure on the idle stud arm making it stay closed tight after moving the throttle cable from WOT back down to idle, at the same time rechecking your first idle aujustment making sure with the cable hooked up it still has the idle drop down speed on the hi side of the aujustment, And some times I will need to reaujust the idle screw some more "just a little bit" with the cable hooked up if I can't seem to get it right with the aujustment of the cable aujuster black knob. The reason for the cable tenshion is for some tmes the engine will stay at a hi idle after going to [WOT] it will not close the throttle all the way down and stay up to 2000 rpms in some cases and that is not good or safe at all so you need to look for that also in your cable aujustments after you think you are all done with it. I hope this helps you some, Good luck.:eek: By the way I know it is a lot to do but [IMHO] If you want it right this is the right way to do it.
DaveM
Re: Motor still idles after shut off?
What you are describing is called dieseling. You don't want this going on, especially with a 4.3L. This engine has a reputation of spinning backwards when this happens and can suck in water.
Make sure your idle speed is correct. Also, let the engine idle for about 10 seconds before shutting it off.
danond
Sounds like it needs a tune-up. After 3 years it's probably due, anyway. Take it in to a marina, have a mechanic get it running right.
Dieseling is bad and fixing it without experience or knowledge can be much worse. Your fuel mixture is off or your timing is off. Either way, setting those wrong can burn holes in things that aren't supposed to have holes in them.
Kalani 938
How much does an average tune up normally cost? I know that's probably a vague question, but maybe someone knows a ballpark amount? Also, what is normally included in a tune up? Thanks guys so much for you feedback! It's a huge help and I really appreciate it.
Ayuh,... I don't buy Tune Ups, but it's no doubt somewhere in the $100. to $1,000. Ballpark....
Depends on the Marina,+ What you ask for....
180shabah
I am a little concerned with:
Ran great - dieseled - was hard to start and idled like crap.
You may have already sucked in a little water. Pull plugs now and look for signs.
OR
it could be coincidence, and all that is needed is a proper tune-up(hope so)
