Motor stuck in Down position. Bad tilt assist cylinder
sunbird1990
Hi my 50 horse Evinrude is stuck in the down position. The tilt assist cylinder is frozen. Do I need to replace this or can I just take it out and chuck it. Motors light enough that I can lift it myself. Any thoughts? :confused:
tx1961whaler
Re: Motor stuck in Down position. Bad tilt assist cylinder
Have you priced the replacement cost of that cylinder yet? :eek:
If the motor can maintain it's proper trim without the cylinder, then I'd consider removing it. I've had a few that did not have a reverse lock and it's OK if you're careful.
