redbandit98
- Joined
- Jul 10, 2012
- 18
sorry, i do not know the correct term for this piece. I had to buy a used complete trim system for my 85 merc XR2. The used unit came with the motor mounting brackets so I just installed it on my motor vs having to take the brackets off the systtem. There are two brass "crush" washers and I installed them on the inside of the bracket. I could not really see where they would do any good against the nuts that screw onto the pin. I tightened the crap out of the nuts and realized the motor bracket would not tilt. (by hand, tilt ram not pinned to bracket yet). I loosened it up a little and the bracket was able to move again. The nut is a nylon lock style so I assume it will not just back off if I dont leave it super tight. Is there a torque spec for this? Did I install the washers in the correct orientation?
I am pointing at where I put the washer. If the picture looks funny its because the motor is hanging from my hoist, so your looking at the front of the bracket/motor that would be bolted to the transom. thanks
