NashForce125
Thread starter- Joined
- Aug 16, 2020
- 9
I picked up a 1985 Force 125 and have been working on getting it water ready.
When I purchased it, the ignition was not firing all cylinders. Compression on cylinders was around 140psi, so I figured I would roll the dice and try to get it going.
I got the ignition sorted out pretty easily and got it on the lake. Motor ran fair, but would stall going into gear at idle. Also found that carb butterfly was not hitting WOT. Thus ends test run #1.
I watched some YouTube videos about how to set all the linkages for throttle and timing. During this setup, I found that a previous owner had rigged up the timing linkage with a bolt tail and a spring. This greatly advanced the timing idle and allow the plastic block to slide when the timing could hit the mechanical stop. See picture in thread from me.
i ordered the correct timing linkage parts and got it set up with a timing gun. I left carb throat covers off since I had been tweeking throttle settings. Engine would not start, and I could see an occasional drop of gas coming out of throats. I found that if I advanced the timing the engine would start.
I figured the carb needles were not sealing, which they were not. So I cleaned the carbs out, got new needles and seats thinking the engine was flooding and the extra idle speed was burning the extra gas, but the issue persists. It will only idle with the timing advanced a lot. To the point that with stock linkage the timing tower cannot go the WOT due to mechanical stops on timing coil. This I would explain the modified timing linkage.
i have looked at the reeds and they are all there and feel like they are pulling air (hard to tell with carb adapters on). I have not removed them to check for light leaks.
I checked my vacuum/recirculating lines and they all seem to hold lung pressure.
What am I missing? Any tips or troubleshooting ideas would be appreciated.
