firefighterco2
- Joined
- Aug 1, 2008
- 28
After replacing the water pump assembly and changing out the lower unit oil the other day, the boat will not go into either forward or reverse. With the motor off it seems like the boat will go in gear from the control. Also with the lower unit off I can manually shift it in gear. But when i put the boat in the water the other day it would not go in reverse at all, it kept clicking like it was trying, and when I put it in forward the engine would rev but the prop was not spinning.
1986 Johnson 50 hp outboard
J50Belcde
On a 21 ft Landau Pontoon Boat
J50Belcde
