marineman16
Thread starter- Joined
- May 22, 2007
- 37
I have looked for a solution to this for a long time. I am not a guru with engines, and I'm pretty new to boating so I could use some help from you experts. I have an '88 Merc 150 Black Max on an 18' fish n ski. It is standard boat with 4 primary seats - 2 mid-boat console seats, and two rear seats in front of the fishing deck.
It is a strong-running motor with the exception of two issues that I'd like to clear up for the upcoming season.
1) If I seat people in the two rear seats and throttle up, the motor revs to just above idle then stays there, completely ignoring the fact that I'm increasing throttle. It won't RPM up to the point of picking up speed and planing - just enough to barely make it nose-up. And yes, I do know how to work the trim! LOL
2) With 1-2 people when I can actually reach higher speed, the motor surges causing random drops of a couple hundred RPM and a loss of a couple miles per hour.
I rebuilt the fuel pump and replaced the gas line and inline fuel filter last season thinking (or at least hoping) both problems were related, and likely a gas issue. However, the problem continued to worse slightly as the season went on.
Does anyone have any advice? Could this be a carb issue? I've had the boat for two years and I haven't had them cleaned. No idea how long it has been. Would there be some kind of a resistance sensor, breather hole, etc that may be forced under water just enough with the extra couple hundred lbs to the rear to make the motor not rev up?
Thank you very much!
