JeffGoldberg
Thread starter- Joined
- Jul 20, 2008
- 5
I have a 1963 75 Hp Vfour Starlite Electric shift.The motor will idle but when I try to bring up the rpms it seems to starve for fuel and stalls most times. Sometimes I can bring it back to an idle and it will continue to run. But if I try to keep the rpms up it slowly goes down in rpm untill it stalls.I can pump the tank ball up and it will start and idle.I tried the same gas ball and hose on my 6 hp evinrude and it runs fine and the ball stays hard so I dont think its the check valve in the ball.So I rebuilt the fuel pump but I had done that only a few years ago and all the O-rings and diaphram looked good.I still have the same problem after the rebuild. I tested the fuel system as my manual says by disconecting the line going to the carb and pumping the ball on the gas tank and fuel flowed freely out of the line. Next i turned over motor and monitored the fuel line to the carb and I saw no fuel comming out thats when I rebuilt the fuel pump.Now when I turn over the motor I get a steady SMALL flow of fuel out of the line that goes to the carb.So i says yippe I got it. I start the motor and I have the exact same problem at high rpm.Should the tank ball stay hard once it is pumped up and the engine is running?I also understand roughly whats driving the fuel pump, "crank case pressure" but I have no way of telling if its working correctly. Someone also mentioned putting a small electric fuel pump in to assist or take over for the original pump. Has anyone done this and had it work?I would like to fix it right rather than monkey rig an add on pump. I look forward to your input. Thanks in advance.
