Motor wont run in water but runs fine out of it.
Becauseican
i have 1985 johnson 40 hp. 1 day i killed it on lake and couldnt get it to start again. i then put new carb kits in it but then it would run fine on muffs and would start fine in the lake but when i engaged gears in the lake it would die so i idled it up a little and now can just idle around bit when i give to much throttle it dies. i done a compression check (without the throttle open) and got 135 on 1 cylinder and 130 on other. i am thinking of taking carbs off and taking them to boat shop and letting them put the kits in. any suggestions?
Re: Motor wont run in water but runs fine out of it.
Check your plugs and wires. I had an issue with mine that I chased for an entire month, turns out it was just my wires. Get it running on muffs and grab the wires one at a time, you will know very quickly if they are bad.
1946Zephyr
Yep, you have an issue with a coil or wires. . I had a customer with this kind of issue and he found out it was a bad coil.
ONERCBOATER
if you have a compression tester it might be worth a look too, running in the water puts more back pressure on the engine.
Sean
Becauseican
I already check the spark. had a good blue spaek on both plugs. i forgot to mention when i put kits in carb i was not able to get the 1 jet out of the bottom of 1 of the carbs before i soaked it. also half the kit i wasnt able to replace. just the float and neddle valve. maybe i didnt do a good enough job?
the smallest little speck can cause you problems with the jets, you shoud tear them down again and do a GOOD cleaning use compressed air to blow out everything. >>>>>>> BTW I had good spark to when I was on land and feet dry, but when the cowlings were on and running there was a short in one of the wires. It cant hurt to check them again. Good luck.
boobie
Did you check the spark with the plugs or with an open air gap tester set at 7/16"??
