Hello all: I need some help. I have a 1992 25hp Evinrude tiller steering, electric start motor. The motor was running fine until last Saturday. While running at almost full throttle, the engine caughed, I looked at the after-market fuel tank and the sides were collapsing, I then opened the vent and the motor ran fine, and the tank regained it's normal shape. About 5 minutes later I went through a no wake zone for about another 5 minutes at a very slow speed, Then the motor died and would not restart( fortunately very close to my slip}. Since then I have replaced the tank with an OEM tank and hose. Taken the carb off and cleaned and inspected it. Checked the filter and disassembled the fuel pump and it "looks" o.k.. Now if I use the primer I can hear and feel the gas going to the carb, and the motor will run until that initial charge of gas is gone. I can keep it running with the primer in the warm-up position and throttle-up at the same time, once I let go of the throttle it dies. I hope I have given enough info, I can't think of anything else. Sorry for the screw-up in the posting, I hit the wrong button. Thank you, Joe Carroll
