Motor won't turn past compression stroke
bullit1119
I have a 1977 mercury 1500 that has started giving me problems. I can turn the flywheel by hand with relative ease but hook it to a battery and it wont spin past compression. Can any one help on this?
Re: Motor won't turn past compression stroke
Sounds to me it's either the battery is weak, bad connection to the battery and starter, bad ground, or starter needs replacing. Put a volt meter on the starter and try cranking the engine, battery should not drop below 10 volts, should be higher.
bullit1119
Thanks for reply, ill give those a look and go from there. Do i need a Marine battery or will regular car battery work?
GA_Boater
Just about any well charged battery should work for testing. For on the water use, you should use a marine battery because they are built stronger internally for all the bangs and bumps a boat sees as it it hits wave, wakes, etc.
bullit1119
Just about any well charged battery should would for testing. For on the water use, you should use a marine battery because they are built stronger internally for all the bangs and bumps a boat sees as it it hits wave, wakes, etc.
Thanks GA
