Motor year??
Kjeremy2
Re: Motor year??
Where did you get 2 sets of valve covers? From the start of this thread you had a motor and no drive. Now you have a drive and 2 sets of valve covers. Don't take it the wrong way. We can get you going again but we need to know what you have.
They came with the boat when i bought it i also have 2 distributers and these little metal rods?.
Kjeremy2
Re: Motor year??
Ayuh,... The 3.0l was virtually unchanged from the mid-60s, through 1990 or '91, when it got a 1 piece rear main seal,...
'n it's been virtually unchanged since,...
alright thank you :D
fishrdan
Re: Motor year??
I agree with Bondo, that the 3.0 engines will be very close, but there have been some changes over the years. If the engines look "identical" (manifold, ignition, wiring, acccessories, etc.) it really doesn't matter if they are the same year, since they are built the same. The oddities come in when crossing years due to differences in the accessories, but those can be swapped over. The biggie is going from a 2 piece rear main seal engine to a 1 piece rear main seal engine (or the other way around), since there are lots of changes there,,, as the whole package goes.
So I take it that this is an uncompleted project boat that you are trying to finish up? Do you have the Mercruiser manual for the engine/drive? That's pretty much going to be the "Bible" for finishing up the boat as you need to know how everything needs to be connected,,,, correctly.
You mention having a MC1 drive, can you post up some pics of that and the transom assembly? Also, is the drive installed on the boat yet? Going from MC1 to Alpha is where there were a lot of changes, but it could work if you have all the right parts.
Re: Motor year??
Ayuh,.... Dan, in post #10, I linked to his outdrive thread,...
It appears to me, he has an '88 boat, with it's native transom assembly, with a MC-1 for it,...
The MC-1 I believe is Beat, so steppin' into an Alpha 1, 1.97:1 ratio, will get 'im back to original,...
The motor appears to be a 2 piece rear main block,...
The accessories are of a questionable vintage,...
Looks like a points distributor to me,....
Carb, 'n manifold,..?? I donno,...
Kjeremy2
Re: Motor year??
Thanks For Wrapping that up bondo?.. i found a 1.98 alpha one locally?? i should be getting it in a few weeks if this weather would warm up a little bit (hate living in New york) so i can get out there and change the oil and filter and spray some gas down the carb to see if she fires up :D
thumpar
Re: Motor year??
Make sure you check alignment before installing the drive.
GaJeff
Re: Motor year??
Mine has the engine serial.number and transom number on the valve cover too. It's part of the engine spec. decal. Maybe one of those covers can give you some info. Take a pic of the spec decals and post them, someone should be able to help with that.
Jeff
thumpar
Re: Motor year??
My current boat has all the serial numbers on the flame arrestor cover but my old boat only had the engine serial on the valve cover label. I think they switch to listing them all at some point but the earlier ones didn't have that label with full serials.
Kjeremy2
Re: Motor year??
i tried too do what bondo had said by pouring a little gas down the carb to see if it starts but turns out my battery isn't strong enough to start it cause it started clicking after one turn of the motor and while i was out poking around i noticed that they ran from the fuel/water separator to the fuel pump then to the carb. o i ordered some fuel lines. does anyone have a battery they recommend??
GaJeff
Re: Motor year??
I run a truck shop so I use big group 31 batteries. I like them because they have the 3/8 studs. I can run terminal rings on my cables. Plus they're pretty heavy duty. If you have something like an interstate battery near, you can get what's called a "blem" battery. They're new batteries that had some kind of defect on the appearance and we're rejected for top line. I get truck batteries at $50-$60 with a $10 core. Usually $100+ for top line.
If your not wanting to spend a whole lot for a battery now that would be my recommendation. You can get blem batteries in any group and in auto or marie.
Kjeremy2
Re: Motor year??
where can i get a blem battery is there a place that sells them??
Kjeremy2
Re: Motor year??
alright thank you..... my next question is for the fuel pump where can i get a bowl for my fuel pump i believe they were glass or is there an updated one that surpasses this requirement... also is there a place i can get the clear hose????...... and last but not least a diagram of how everything hooks up from the pump to diagram I've searched with no luck :/
Re: Motor year??
Ayuh,.... Ya need a New Fuel Pump, Complete,....
Parts for that pump ain't available, piece by piece,....
Both the fuel pump, 'n the tubin' can be found right here at iboats megamall,....
'n look in the Adults Only section for the Merc manual that covers yer motor,....
Everything is covered in it,...
GaJeff
Re: Motor year??
For the most part iboats has all the parts you would need and all the information on how to install/repair it. Just got to download the manuals.
Jeff
Kjeremy2
Re: Motor year??
thank you i found the pump but in the picture it doesn't show the glass bowl its just the metal piece of the pump with a gasket the part number is 861676A1.
