fishinspot
- Joined
- Jul 22, 2006
- 25
I did check spark this morning and it was over 1/4" gap. I then was able to start it up quickly. Seems this engine does not like to be chocked. With no choke it starts great. Runs and idles very well. Tried several start stops and it worked well. Let it set a few hours and started right up again with no choke. Go figure. Once that was figured out I tried shifting gears. No go. I looked at shift rod connector thinking maybe I didn't get the shaft seated well and it slipped. It was indeed slipping and couldn't get it back in due to a stripped thread in rod connector so took lower unit off to fix threads. Tried shifting gears manually with lower unit off and it wouldn't shift into gear. Felt stuck somewhere. Drained lower unit oil and low and behold it was very milky. Decided to open up lower unit and it looked pretty bad. Lost seal somehow and leaked in water. I think it was due to fishing line wrapped in the gear case head and trashed the o-ring. Clutch dog was stuck on shaft. That thing wouldn't budge. Tore everything apart and looks like all the gears/shafts are good so working on cleaning everything up and then will check it all over real good and order all new seals/gaskets for lower unit. Didn't want to have to do all this but bought an old used engine so it happens. Looks like the biggest pain will be trying to remove the front dowel that holds the forward bearing in place. It was pushed down into the housing and barely sticking up. Can't grab it. Not enough dowel to get a hold of.
You guys just drill these out? What a pain!
