tahoejag
Thread starter- Joined
- Jul 4, 2009
- 229
06 Q6 S/F - Looking to upgrade existing hand contr 55lb motorguide motor. It is a good motor (more designed for a calm inland lake), however, the water conditions of Lake Huron and river currents and winds; the 55lb thrust does not cut it at all attached to a Q6. Im looking to upgrade to the Motorguide wireless 75lb or MinnKota PDV2 80 lb. (is this enough motor thrust?) Seems like the 54" shaft may be just enuff, or should i go with 60" shaft. Both motors are within aprx $100 of each other with Motorguide being more. I like the fact that u can be anywhere in the boat and run either motor without being restricted to the front with a pedal where there's not much room. Thru other posts I have seen only the Motorguide wireless adapted to the original mount, but have not seen anything on a MinnKota. Any input and/or opinions in making my selection are greatly appreciated in advance!
