Motorguide Voltage for 41 lb thrust?
PhilC
The trolling motor on my recently-bought boat has an upper unit marked "Motorguide Brute Mod. 750 12/24 volt 45 lb. thrust", but the lower unit, which is the electric motor, is labelled "Whisperguide Propulsion System 41 lbs Thrust". Obviously, someone has changed the lower unit. My question: Is the existing lower unit (the 41 lb motor) also rated for 24 volts? I am currently using it on 12 volts, but want to wire it for 12/24. Thanks.
snapperbait
Re: Motorguide Voltage for 41 lb thrust?
For some reason, my gut says the 41 is 12 volts, but not 100% sure....<br /><br />I would try http://www.trollingmotorparts.com/.. Might contact them or try their message board, as they could likely give you a better answer...
PhilC
Thanks, Snapperbait.<br /><br />Also, an ad on www.bassjons.com suggests they might have made them both ways.<br /><br />PhilC
