MikeWhitfield
- Joined
- Jul 1, 2005
- 4
I just bought an 1984 Stott Craft, and I need to mount my 1975 Mercury 650 on it. The Mercury is a clamp-on with bolt holes on the bottom, but the pattern is not BIA (it's narrower.) The boat is drilled for a BIA-standard - it had a Yamaha 50 with oil injection whose owner decided to pre-mix without modifying the engine, removing the oil injection, or even re-jetting, and blew it up. Does anyone know of an adapter plate, jack plate, etc. that will bolt to an old Merc and to a BIA-drilled boat? So far the only thing I've seen is the CMC tilt/trim with transom-mount adapter,and that's quite pricey. Panther has a drillable spacer plate, but it's only drillable in the same vertical plane as the BIA pattern - won't work for my purposes. <br /><br />Thanks!
