Mounting a fuel filter/separator
mphy98
I have a new fuel/water separator to install. Is it ok to mount it in the splash well ahead of the outboard? It is a 19' starcraft superfisherman. I like that location because it would be easy to get to. I could drain any water right out easily and see it every time I take out the boat. The gas line comes through right there as well. Thanks for your thoughts, bob
robert graham
Re: Mounting a fuel filter/separator
Yep, that's where to mount it, take your time and mount it so your fuel lines don't kink or bind when you steer the motor. Good Luck!
