Mounting a outboard
wisemack34
Are they a WEBSITE that shows me the right way to mount my 90 hp outboard motor.......thanks for your help
Silvertip
Honorary Supreme Mariner
Re: Mounting a outboard
New boat -- old boat, is the transom pre-drilled for the mounting bolts. Give us something to go on! Otherwise center the engine on the transom and mount it so the antiventilation plate is flush to an inch or two above the bottom of the keel. Bolt it on using stainless bolts and sealer to prevent water from getting into the holes. You will probably need to attach the steering cable before mounting the engine. That cable is not very flexible.
seahorse5
I don't know of a website but Evinrude came out with a complete rigging manual that shows everything from how to locate the center of a transom to installing batteries, gauges, wiring, and of course the engine.
You can order one from any dealer under part number
#5007085
