JacksOutrage
Thread starter- Joined
- Dec 31, 2023
- 7
1998 Outrage 23 Evinrude 225
Recently acquired boat and after transporting ~300 miles noticed that one of the mounting bolts had compressed into the transom and motor has pulled away ~1/8". pics attached.
Prior to trailering, the boat had gel coat cracks, but I didn't notice any compression. The other bolt looks fine, and motor is firmly against transom.
Q1: Research says everyone goes to waterlog, but I'd like to hear thoughts on replacing washers with a transom saver (metal plate/washer) before going to worst case scenario.
Q2: I didn't use transom saver (for trailering), the original owner said that it had been trailered in the locked position several times with no issues. I should have done more research. I still need to trailer it another 400 miles to final destination but am not sure what I can/should do beyond purchasing a transom saver prior to trailering. I could tighten bolt, try to replace that washer with bigger plate (though I don't have a lift and my boat guy is in SC).
thoughts appreciated. I'm new to this forum so apologies in advance if I'm breaking any rules.
thanks, jack
thanks, jack
