mounting engine to transom
JT!
can i just use the 2 screw clamps to attach my motor?
or am i supposed to drill thru the transom and mount bolts in the 2 lower holes of the motor's bracket? must I do it?
Barnacle_Bill
Re: mounting engine to transom
You can use just the screw clamps. Just make sure they are tight and check them often.
JT!
attaching a '71 evinrude 50HP to a gutted 1962 arkansas traveller.
tashasdaddy
50 needs to be bolted also. if it were a 25 ok.
CATransplant
Heck, I even bolted my 6hp Johnson to my boat with the two bottom holes. More to keep it from being stolen than anything else, but those clamps do have a way of vibrating loose.
Stainless bolts and nylon insert self-locking stainless nuts, with washers on the inside of the transom. It's worth it.
