Thanks for the reply. I was thinking a quick release bracket might be necessary. Do you think I should mount it to the side or as close to the center as possible? That second option will require me to do something about the bow lights.Yes you can mount a trolling motor on it just make sure you have it on a quick release bracket. So when you want to have family fun day you can remove it. You will need the bracket and a power plug disconnect to remove. I am doing the same thing on a pontoon now it is going right in the middle of the front gate where everybody get's in and out when we beach it so when not fishing and just having fun can remove for the day. Plus you will need a extra battery for power and a on board battery charger for the extra battery a little bit of work and money but well worth it.
Thank you for the welcome. I just got the motor today and have spent a couple hours now assessing my options. It's going to take some creative thinking, but that quick release might be the key.You will have to get the trolling motor and just see where it will fit on your bow. You can mount it a little offset and close to center check u tube on the Edge for installing should give you some ideas. Oh and welcome to i boats![]()
Can you point me to anything that shows this done? My tail doesn't go all the way around the bow. It stops at the end of the seat. Here's a photo.The simplest and least expensive way is the screw-clamp-on-the-bow-rail style. In this method of mounting, the shaft of the motor has a plastic or composite block that clamps onto the stainless steel railing as close to the centerline of the boat as possible. Securing the shaft to the railing is accomplished by tightening two large thumbscrews.
Nice work! I only recently got back to trying to sort this out. Thought I'd cut a wedge to even it up with the prow and angle the mount along the bow, but I failed to account for how the until will sit when the prop is out of the water. Back to the drawing board!Finally got mine hooked up works great plus I did make a plate to go under more support worked great on the test run.
How is yours coming a long.?
