Mounting VHF Antenna
badrano
What is the correct way to mount an antenna to the gunwale? Do you use screws or bolts? If you use bolts, should there be a back plate on the other side of the hull or are large washers enough?
dingbat
Bolts with backing plate
Backer doesn’t need to be thick. 1/4” is more than enough
harringtondav
I used a SS hand rail clamp for mine at the aft corner. It worked fine with my 8' antenna. Now I use a short whip antenna. Still fine.
badrano
I thought of using the railing but with my luck, one of the kids would end up grabbing on it, plus I only have railing forward of the helm by the bow seating area.
dingbat
Wow, 1/4" seems really thick. I was thinking of no more than an 1/8".
really depends on the thickness of the glass your bolting to. You could get by with fender washers if the glass is thick enough.
dezmond
1/4" Wood for backer... if you use metal plate, 1/8 should be fine.
