mounting zinc on an aluminium hull
bobbymcgee
Salt water use. We have problems with pitting on our 17ft aluminum hull. I am planning to mount a zinc plate in addition to the old ones that are attached directly to the hull.<br /><br />Should the zinc plate be in electrical contact with the hull or isolated from it an attached to the boats electrical systems ground?
umblecumbuz
Re: mounting zinc on an aluminium hull
Hi Readytogo,<br /><br />You can get info on the principles of galvanic corrosion from FAQ - 'Dealing With Corrosion ...'<br /><br />Short answer is this: <br /><br />You need to fit a lump of metal to your boat that will get eaten away (sacrificed) at a faster rate than the aluminum. The wider apart on the galvanic table the two metals are, the better this will work. Fitted in proximity is good (like fitting a zinc to an outboard leg, which will protect the hull, prop, boarding ladder, etc also), but fitting it to the hull by direct contact (riveting, bolting, screwing) is better.<br /><br />If your hull is suffering, be generous with anode sizing. The level of protection is dependent on both anode material and size. Keep the anode cleaned of any oxide buildup (furry-looking surface) with a file if needed, and replace it when it's half gone. I don't replace mine when half gone - I just bolt on a new one and let the old one vanish to nothing.<br /><br />One other detail. Always use fixings that are more 'noble' than the anode itself, otherwise they may corrode first and you lose your anode.
bobbymcgee
With pitting observed in both the bow and the stern bottom surfaces should I mount some zinc to the bottom in the bow area (seems like kind of a weird thing to do) as opposed to all on the stern plate?
Dunaruna
Triple check your grounds - sounds like a leak somewhere - possibly, maybe.<br /><br />Is it wet moored or trailered?
imported_scott_m
Agree, sounds like you could have a lose ground wire...I just went thru the same thing on my 36 ft cruiser - although FRP, it was eating thru zincs like they were going out of style - turned out one of my battery cable clamps had broken and although the ground wire appeared tight, it was not. Guess where all that stray DC went? Straight out the props and shafts.
