Rscardina
- Joined
- May 3, 2010
- 513
Thanks to all the help here, a proper manual, and beer..I was successful in changing out the upper and lower mounts n my 1986 Evinrude 140HP. Model
e140TXCDC, G1136668.....however!! Once I got everything back together I decide to give her a run. I set up the rabbit ear, turned on the batteries, primed the bulb...and she cranked but no start. I checked the primer bulb and she was still solid..even afetr all those cranks.. SOOO...I assumed that maybe she needed to crank a bit more to get the fuel up..but after several crnck and my battery starting to die..I decide to stop and ask for help.
My question is..it did start fine before I took it apart to do the mounts..I also was sure to mark everything so I knew exactly where it came from.. I have no extra pieces which is good..
so why the heck wont she start?
Anyone run into this before? I didnt change throttle ro shift linkages, didnt move anything, I was so careful as to keep everything as it was before I started...
My plan is to charge my batteries and give it a try tommorrw.. can anyone give me a clue as where to start..anything jumping out when you remove a powerhead..
Thanks
Thanks
