mq10 wont run with cowl
crunchnmunch
so iv been working on restoring a 1964 9.5hp mq10 and have gotten it to run pretty good but this hole time iv never had the cowl on. so i finally had it on and it wont start, took it of and she runs, slowly put it on and it dies. any ideas would be awesome
Barnacle_Bill
Re: mq10 wont run with cowl
If the carb is adjusted properly look for an exhaust leak under the cowl.
JB
Exhaust leak. Fairly common on MQs
TN-25
Knowing about the exhaust leak issue with the 9? and the problem of torn or cracked bellows in the lower leg I decided to check it out on any motor I considered buying. Before I bought my 1967 MQ-13, I ran it and trolled with it with the cowl on to check for the exhaust leak. It made no difference so I bought it. Later I saw a little hole drilled into the starbord side of the pan, just below and back from the shifter. I thought somebody had pulled a fast one by doing a quick and dirty fix, but after looking around at others, plus some brochure pictures I came to realize that the factory put that hole there. Dad's 1965 MQ-11 did not have the hole.
crunchnmunch
ya mine doesnt have that hole. would not having the best tune really make it die when the cowl is on. also what part am i looking for a leak is the bellow where the water gets pumped out
crunchnmunch
well found my leak not sure what its called but it was right under the carb when i opend it they looked like reeds. the bottom of the gasket was gone it and was just shooting out gas(maybe exhaust as well).i pulled the old gasket cut a new one and was able to run the motor with the cowl on
crunchnmunch
set up a fan to try and get rid of some of the exhaust the motor runs pretty good now with a fan and the cowl on. noticed today that there are two holes on the sides of my cowl but they have a tar over the hole on the inside. wondering if any one else has the same holes b4 i remove the tar
also made some new gaskets for the carb and a new stopper(was cracked)
