Re: Mud Motors
You might consider putting an air prop on that Honda motor and make an airboat out of it. Use the old Merc to get you through the deep water to your shallow spot, then tilt the Merc up clear of the water and fire up the Honda air motor to scoot you through the shallows.
I've driven airboats, mudboats, jetboats and prop boats. The airboat will get you over/through the most obstacles, but they have their issues. A good tunnel boat will go anywhere that a mudmotor or jetboat will go, but you have to have it properly set up, which is a major PITA and few know how to do it properly. This is why those who run mudmotors or jetboats claim they run shallower than a tunnel prop, because they've never experienced a good tunnel prop setup that will run just as shallow.
