Multi Tach for Yamaha
FishinMission
Just installed a Multi Tach for my 2004 200V/Max.<br />Everything seems to work fine except the light.<br /><br />Did I miss something?<br /><br />I'm in the dark.<br /><br />Help.<br /><br />Thanks in advance...<br /><br />Mark
nanoa
Re: Multi Tach for Yamaha
fishinmission <br />YOu should have a blue wire coming off the tach itself you need to connect it to the ignition wire on the control unit which is usually yellow thus tach will light with key on. many times you will find a plug in for the ignition wire under your dash near the guages.<br />Good luck
FishinMission
Got it! Thanks....<br /><br />Geez...is there a way to get that light for the tach to be brighter?<br /><br />You can almost tell it's on.<br /><br />Mark
nanoa
I think you will find it to be a lot brighter at night my is very easy to read after dark
